Episerver specialized property error
Hi, I am getting the following error on my search results page.
Type 'EPiServer.SpecializedProperties.PropertyXhtmlString+UrlString' in Assembly 'EPiServer, Version=5.1.422.4, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' is not marked as serializable.
Exception Details: System.Runtime.Serialization.SerializationException: Type 'EPiServer.SpecializedProperties.PropertyXhtmlString+UrlString' in Assembly 'EPiServer, Version=5.1.422.4, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' is not marked as serializable.
Source Error:
Stack Trace:
[SerializationException: Type 'EPiServer.SpecializedProperties.PropertyXhtmlString+UrlString' in Assembly 'EPiServer, Version=5.1.422.4, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' is not marked as serializable.]    System.Runtime.Serialization.FormatterServices.InternalGetSerializableMembers(RuntimeType type) +2700482    System.Runtime.Serialization.FormatterServices.GetSerializableMembers(Type type, StreamingContext context) +245    System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitMemberInfo() +88    System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.InitSerialize(Object obj, ISurrogateSelector surrogateSelector, StreamingContext context, SerObjectInfoInit serObjectInfoInit, IFormatterConverter converter, ObjectWriter objectWriter) +175    System.Runtime.Serialization.Formatters.Binary.WriteObjectInfo.Serialize(Object obj, ISurrogateSelector surrogateSelector, StreamingContext context, SerObjectInfoInit serObjectInfoInit, IFormatterConverter converter, ObjectWriter objectWriter) +50    System.Runtime.Serialization.Formatters.Binary.ObjectWriter.Serialize(Object graph, Header[] inHeaders, __BinaryWriter serWriter, Boolean fCheck) +438    System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Serialize(Stream serializationStream, Object graph, Header[] headers, Boolean fCheck) +131    System.Runtime.Serialization.Formatters.Binary.BinaryFormatter.Serialize(Stream serializationStream, Object graph) +13    System.Web.UI.ObjectStateFormatter.SerializeValue(SerializerBinaryWriter writer, Object value) +3010  [ArgumentException: Error serializing value 'EPiServer.Core.PageDataCollection' of type 'EPiServer.Core.PageDataCollection.']    System.Web.UI.ObjectStateFormatter.SerializeValue(SerializerBinaryWriter writer, Object value) +3217    System.Web.UI.ObjectStateFormatter.Serialize(Stream outputStream, Object stateGraph) +126    System.Web.UI.ObjectStateFormatter.Serialize(Object stateGraph) +52    System.Web.UI.ObjectStateFormatter.System.Web.UI.IStateFormatter.Serialize(Object state) +4    System.Web.UI.Util.SerializeWithAssert(IStateFormatter formatter, Object stateGraph) +37    System.Web.UI.HiddenFieldPageStatePersister.Save() +106    System.Web.UI.Page.SavePageStateToPersistenceMedium(Object state) +82    System.Web.UI.Page.SaveAllState() +550    System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2357
I am using episerver index searching. I cannot figure out what the problem. Can anyone shed some light on this.
 Thank you.
Ramesh
#19587
Apr 21, 2008 3:37
This is a known bug in our system:
Bug 50566: String fragments are not serializable which may cause failure on serialization of PageData objects
It has been fixed in CMS 6 R2 release.
#49297
Mar 11, 2011 15:05
The exception message seems to deal with EPiServer CMS 5 so it's probably not the bug Tobias assumed. The exception states that there are built in properties that are not serializable. I don't know if this is the case but perhaps you could solve this by not serializing an entire PageData-object. Perhaps store a PageReference instead?
Regards
Linus Ekström
#49298
Mar 11, 2011 15:57
