Using asp:substitution
I'm trying to use an asp:substitution control on a page, with outputcache turned on.
But it doesn't work, the static method is never called after first visit.
Just testing with a simple date time output. Works fine outside epi.
Anyone tried the same?
I'm running CMS SP2.
Erik
#25804
Nov 06, 2008 11:19
Response filtering (friendly url rewriter) is not compatible with substition blocks, on IIS 7 you actually get an exception.
#25839
Nov 07, 2008 10:08
You should be able to solve it using Ajax instead.
#25840
Nov 07, 2008 10:11
Too bad the Substitution control is incompatible...
#58295
Apr 18, 2012 11:54
