Export frames
What is the Export frames option for in EPiServer Admin/Tools/Export Data? I see _blank and _top child options available, but I do not get how it is used. Thanks, Martin Kulov ProPeople ApS
#15972
Jan 22, 2008 9:41
Hi Martin! If you have added your own frame definitions (admin->config->edit frames) you can select to export them in your export package. The two frames that you see are the default frames.
#16724
Jan 22, 2008 12:10
Thanks Linus!
#16725
Jan 22, 2008 12:27
And what is the Export tabs option also?
#16726
Jan 22, 2008 12:54
The tab definitions are the possible tabs where you can place your page properties that are used when editing a page. Import/export works the same way as with frames.
#16727
Jan 23, 2008 11:44
