Link Properties
If I create a link in the text editor in EPiServer that points to a "virtual" target, in my case a HTTP-handler, then select that link and opens the "Link Properties..." from the right-click meny, or clicks "Insert hyperlink" in the toolbar, I get a message with this message: "The document that this link was linking to does no longer exist or has been moved. Select a new document before saving, or change to another type of link." The link itself is not displayed at all in the dialog, making it impossible to use this dialog if I for example want to change the text/target/title/etc. of the link. Is there a fix/workaround for this?
#15683
May 16, 2007 9:56
