Error when creating GUI plugin
Hi. When I'm trying to create a GUI plugin I get the following error message: "A call to InitiateConnection must be performed before calling InitializeHost". This message is shown after I have selected plugin type. /erik
#15690
May 28, 2007 10:01
This will happen if a wizard as in this case calls into the EPiServer appdomain within the Visual Studio process and that appdomain for some reason has been dropped. This is probably caused by a bug in the appdomain handling in the Visual Studio integration and we would very much like to have information about how we can reproduce this. Does the problem go away if you restart Visual Studio?
#16158
Jun 01, 2007 12:40
Problem still exists after restarting VS. Other wizards works fine.
#16159
Jun 04, 2007 14:54
