SearchDataSource and *.pdf files
I´m using the SearchDataSource and a repeater to create a searchpage. The SearchFiles and SearchLocations propertys is set and the indexingservice is running but I get a null reference exception when the select method is executed. This only accours when I get a valid filehit. Anyone with the same problem?
#15934
Dec 17, 2007 15:35
Yes, I have the same problem and reported it to EPiServer a few weeks ago. Apparently this is a known bug and it will be fixed in the next SP/hotfix. Regards, Magnus
#16662
Dec 17, 2007 18:00
Ok, thanks!
#16663
Dec 18, 2007 8:39
I am also facing the same problen..Any solution on this?
#31852
Aug 12, 2009 16:11
