Property dependencies
Hello, Is it possible to add some kind of page property dependencies in EPiServer CMS 5? If a page type has 2 properties, MainImage and MainImageAltText, I would like MainImageAltText to be required only if MainImage is filled. Any ideas?
#15834
Oct 19, 2007 11:29
Hi Mattias! Read the following post for some information on how this can be done: http://www.episerver.com/en/EPiServer_Knowledge_Center/Developer-Forum2/EPiServer-Developer-Forums-/EPiServer-CMS-version-5/13703/ It's also possible to couple two properties with one user interface with the new property model although this is a bit more complex. The trick is to have one property without a user interface and the other one displaying the user interface for both of the properties.
#16454
Oct 22, 2007 10:21
OK, thanks for your answer. It's exactly what I was looking for. Problem solved :) /Mattias
#16455
Oct 24, 2007 11:16
