You can read more about custom rendering blocks from content area here
http://joelabrahamsson.com/custom-rendering-of-content-areas/
It's possible but normally cheaper to take gui developer in the ear to make html match the standard with containing tags etc / use multiple content areas...
Im sorry but Im not sure what you mean.
Basically I am using a search such as:
var pages = DataFactory.Instance.FindPagesWithCriteria(PageReference.StartPage, criterias, lang.LanguageBranch);
and I need to loop the pages to get the content from this control:
<Extension:ExtensionContentArea ID="ContentMain" Description="Main Content Area" runat="server"></Extension:ExtensionContentArea>
Is this possible?
Jon
Also, the language branch doesnt seem to bring back the correct URLs to the page - they are still in the default english lanuage.
I have found this link:
http://marekblotny.blogspot.co.uk/2009/06/episerver-composer-how-to-load-content.html
BUT - on line 6 it is using Page - which im not sure how I can use this - as I am running this feed as an RSS feed in an ashx using FindPagesWithCriteria
Can anyone help?
Jon
For everyone who wants to know this is how I did it:
public string GetContentFromCompaoserBlock(PageData child)
string output = "";
var structure = PageDataManager.LoadPageStruct(child.PageLink);
var contentArea = structure.GetContentAreaById("ContentMain");
try
ExtensionPageData page = ExtensionPageData.Load(child.PageLink);
if (page != null && page.AreaCount > 0)
List<ContentFunctionData> functions = page.GetAllContentFunctions(true);
if (functions.Count > 0)
foreach (var item in functions)
ContentFunctionReference cfr = new ContentFunctionReference(item.FunctionID, item.WorkID);
PageData pdCurrent = EPiServer.DataFactory.Instance.GetPage(cfr);
if (pdCurrent.PageTypeName == "[ExtensionSys] Text")
output += pdCurrent.Property["Content"].ToString();
else
output = "NOTHING";
catch (Exception ex)
return output;
I have a feed that I would like to pass the HTML markup from a specific contentArea of a News article page. At the moment I get the Pagedata of all the article pages via a webservice but I need to get the markup from an ExtensionContentArea by Id per article page.
Is this possible and if so how is it done?
Jon
