Setting 404 on unpublished pages
At present, at unpublished page goes to the log in screen. This still means Google is still picking it up in their results, which we do not want.
I've looked at some previous solutions which involved either overiding the AccessDenied() method or HandleAccessDenied().
This is what I'm using in HandleAccessDenied:
protected override void HandleAccessDenied()
            Response.Status = "404 Not Found";
            Response.StatusCode = 404;
            Response.End();
            base.HandleAccessDenied();
With HandleAccessDenied() in global.asax is it seems the code doesn't get fired when looking at an unpublished page (logged in or not), so this does not seem to help me on that front.
AccessDenied(), I've tried implementing the code from this article:
http://world.episerver.com/forum/developer-forum/EPiServer-CMS-6-CTP-2/Thread-Container/2013/10/Visitors-get-redirected-to-EPi-login-page-when-visiting-expired-page/
And not getting much joy. It doesn't seem to work in our pagetypebase class (in our entities project), with it being unable to see the AccessDenied methods to override and unable to resolve the various symbols contained within the code. I do have a TemplateBageBase class, in the web project, which the code works with, but only a handful of the pages use that class and I don't appear to have others that I could try (also it seems the TemplatePageBase is derived from PageTypeBase - but as said, that doesn't like the code there).
Please help as I feel I'm going round in circles with this. ;)
#122307
May 29, 2015 16:31
As mentioned in this article, the easiest way is to override AccessDenied() in your templates or base class for your templates.
public override void AccessDenied()
    // Important! Do not access CurrentPage directly with an anonymous user
    PageData currentPage = DataFactory.Instance.GetPage(this.CurrentPageLink);
    if (!this.IsEditOrPreviewMode && (!currentPage.CheckPublishedStatus(PagePublishedStatus.Published) || currentPage.IsDeleted))
        Response.End();
    base.AccessDenied();
#122310
May 29, 2015 17:53
Hi David,
Unfortunately neither of those solutions work for me (site is aspx based).
After some further investigation it seems the reason Visual Studio won't accept the override code is that the method simply doesn't exist. I'm looking at my base pagetype class (this is not a project I started myself. It's an existing client one) and it extends TypedPageData, which is a class in the PageTypeBuilder package. It doesn't extend PageBase (which has the AccessDenied method). I'm pretty new to EpiServer, so I'm still getting used to how it all works but this seems to be the reason why the above methods do not work.
So if anyone knows how to implement an AccessDenied on PageTypeBuilder based pagetypes I'd be very glad to hear them.
#122377
Jun 01, 2015 15:37
Apologies Simon, should have checked the forum thread properly and seen you are on CMS 6 R2! You need to override the AccessDenied method in the rendering template, not on the pagetype itself. Can you paste an example of your template and base page type?
David
#122379
Jun 01, 2015 15:55
For reference your base page should look something like this:
public class SiteBasePage<TPageType> : TemplatePage<TPageType> where TPageType : TypedPageData
        //Do your work here
    //Other code
and your template page should look something like this:
public partial class YourPageTemplateName : SiteBasePage<YourPageTemplatePageType>
    //Other code
#122380
Jun 01, 2015 15:58
Hi David
We realised we had more base templates (for things like composer pages and such) so we're created a new class that implements the above AccessDenied method and inherits our basecomposer. Then we've switched the composer templates to inherit from the new class, to save us putting that method in on every template. Same for the other base templates.
This is working now, thank you.
#122407
Jun 02, 2015 12:03
Hi Simon that's great news!
#122408
Jun 02, 2015 12:08
