Are you able to access edit mode? http://Yoururl/YourSecretToUI/Edit/default.aspx?
Did you install the alloy templates or was it just an core application installation?
If you can access editmode then you could create a page and then go into episerver.config and set this pages id (you can see it from hoverning the created page) as the startpageId
You can get that type of error if you have a default.htm file in the root. If you have try to remove it.
Thanks for your replies. @Per I have already removed the default.htm file.
@petter - I have tried accessing the page and it said resource not found, i have tried installing alloytech site and new installation of both episerver 6 r2 as well, still get the same error.
Ram
When installing episerver cms 6 on a win 8 machine you need to configure win 8 so that you are able to install. You could try these links with sugestions on how to install cms 6 on a win 8 machine:
http://dotnetcake.blogspot.se/2012/06/installing-episerver-6-r2-on-windows-8.html
http://www.david-tec.com/2013/03/Running-an-existing-EPiServer-CMS-6-R2-on-Windows-8/
http://www.danielnordmark.se/install-episerver-6-r2-on-windows-8-iis8-and-sql-server-2012/
I have installed Episerver CMS 6 r2 on windows 8 machine and the installation was all good. Then I go to the home page i get "There is only core installation files exists" message. I refresh the page again i get to page with this error. As I am new to the whole episerver and ASP.NET. any help would be highly appreciated. I use IIS 8 , windows 8 and below is the error i get.
Ram
Error:
Object reference not set to an instance of an object. Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Source File: c:\Windows\Microsoft.NET\Framework\v4.0.30319\Temporary ASP.NET Files\root\ba867242\bf776f75\App_Web_2cpigfbr.0.cs Line: 0
Stack Trace:
