Serious Error With LinkItemCollection
I have a CMS 6R2 project and with a particular page that contains LinkItemCollections AND when there is a published version of the page and a version not ready I am getting the error below (on Save and View and Publish) which suggests a problem with the LinkItemCollection:
[ArgumentNullException: Value cannot be null.
Parameter name: input]
   System.Text.RegularExpressions.Regex.IsMatch(String input) +7026582
   EPiServer.UrlBuilder.Init(String url) +47
   EPiServer.Web.PermanentLinkMapStore.TryToMapped(String url, UrlBuilder& mappedUrl) +78
   EPiServer.Web.PermanentLinkMapStore.TryToMapped(String url, String& mappedUrl) +85
   EPiServer.SpecializedProperties.LinkItem.GetMappedHref(Boolean addPreferredLanguageIfEmpty) +65
   EPiServer.SpecializedProperties.LinkItemCollection.Equals(Object obj) +149
   EPiServer.Util.VersionMerge.CreateDiff(PageData originalPage, PageData newPage) +558
   EPiServer.Util.VersionMerge.DiffAndMergeChanges() +55
   EPiServer.UI.Edit.EditPanel.MergePage() +86
   EPiServer.UI.Edit.EditPanel.SavePage() +266
   EPiServer.UI.Edit.EditPageButtonControl.Save(SaveAction saveAction, Boolean goToViewPage) +103
   EPiServer.UI.Edit.EditPageButtonControl.Save_Click(Object sender, EventArgs e) +17
   EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +90
   EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +170
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +29
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2981
In the database I have set all LinkItemCollections on the page to null and actually deleted them as well but I still get the error when selecting Save and View or Publish.
We have recreated the page from scratch which was fine to start with but then this started happening again which suggests it's a content issue. This is becoming a problem as a client needs to publish a page.
Has anyone seen this before or know how I might track down the undelying cause?
Thanks in advance,
Mark
#86239
May 16, 2014 11:54
