What is the error you get when attempting to upgrade through the Deployment Center ?
Sounds like you need to create a support ticket?
Thank you for your answer.
After those actions:
EPiServer CMS Deployment Center
Upgrade site with SQL Server database (Version 7.0.586.1)
Show All Sites -> Choose
After clicking through the form I get the following error message:
Error - Ungültiger Spaltenname 'ContentGUID'. (means something like invalid column name)
Get-EPiIsBulkInstalling
At C:\Program Files (x86)\EPiServer\CMS\7.0.586.1\Upgrade\System Scripts\Upgrade Site To 7 (SqlServer).ps1:230 char:40
+ $globalBlockFolderId = Get-EPiContentId <<<< -ContentTypeGuidString "E56F85D0-E833-4E02-976A-2D11FE4D598C" -ConnectionString $selectedApplication.SiteDbConnectionString
System.Data.SqlClient.SqlException (0x80131904): Ungültiger Spaltenname 'ContentGUID'.
at System.Data.SqlClient.SqlInternalConnection.OnError(SqlException exception, Boolean breakConnection, Action`1 wrapCloseInAction)
at System.Data.SqlClient.TdsParser.ThrowExceptionAndWarning(TdsParserStateObject stateObj, Boolean callerHasConnectionLock, Boolean asyncClose)
at System.Data.SqlClient.SqlDataReader.TryConsumeMetaData()
at System.Data.SqlClient.SqlDataReader.get_MetaData()
at System.Data.SqlClient.SqlCommand.FinishExecuteReader(SqlDataReader ds, RunBehavior runBehavior, String resetOptionsString)
at System.Data.SqlClient.SqlCommand.RunExecuteReaderTds(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, Boolean async, Int32 timeout, Task& task, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method, TaskCompletionSource`1 completion, Int32 timeout, Task& task, Boolean asyncWrite)
at System.Data.SqlClient.SqlCommand.RunExecuteReader(CommandBehavior cmdBehavior, RunBehavior runBehavior, Boolean returnStream, String method)
at System.Data.SqlClient.SqlCommand.ExecuteScalar()
at EPiServer.Install.CMS.SqlServer.Cmdlets.GetContentIdCmdlet.ProcessRecord()
at System.Management.Automation.Cmdlet.DoProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()
ClientConnectionId:1495911a-5494-449f-8032-88d010cd0c3a
If there isn't a short solution for this, I will open a support ticket.
Hi EPiServer Pro
Has anyone tried to Upgrade EPiServer CMS 6 R2 to EPiServer 7 manually?
Sadly the Upgrade with the EPiServer Deployment Center fails with a SQL-Errormessage. Seems that the script can't find some column names like the GUID.
I could consider to reverse engineer the upgrade scripts. But they seem very complex and I'm not really familiar with the powershell script language. And if someone out there already done that, I would gladly appreciate that.
Thanx for any hints on this matter.
