How to change the URL language parameter as per the Replacement Language?
We are having a website with several languages.
We have created a page-"Register" for "Europa-Deutch" (de) language, and we set this page as a replacement language for "Deutsch (Deutschland)" (de-DE).
When we referred the website as http://examplesite.com/de-DE/Register/, we can see the page is loading from (Europa-Deutch) language, which is perfect.
In the page we are loading some values(Like filling dropdowns) based on language parameter in URL.
Since the URL is still appearing as "de-DE" instead of "de", some controls are not loading.
So, can you please suggest me what else, I can try to change the URL language parameter according to replacement language also.
Many Thanks.
#84999
Apr 10, 2014 16:00
In Admin, what prefix do you have for German when you Edit Language Branches?
#85700
May 02, 2014 11:34
