XForms in EPiServer 6 R2 (.1000)
We have problems when editing existing XForms in IE 11 on EPiServer 6 R2 (6.1.379.1000).
Normally when you want to edit an existing XForm and you open up the list the right XForm you are moved to the right page and the XForm is preselected. That doesn't work anymore.
The XForm is preselected but you don't end up on the right page therefore you can't edit it before you have find it by going through the pages.
Not a big problem with a few XForms but when you have hundreds it's really annoying.
Anyone else that can confirme this problem (or better may have a solution)?
To test it you have to create at lest 11 XForms to get more than one page.
Name them A1, A2 etc. then create a new XForm called B (that ends up on the second page).
Then open the XForm list again. You will be placed on the first page. Not the second where you should.
We have tested this even in the demosaite Alloy Tech with the same result.
Tested with IE 11 and Chrome.
#114035
Dec 03, 2014 10:44
