EPiServerException on RightClickMenu
We are experiencing the fellowing exception when we start portal2 from portal1. Portal 1 har the posibility on right click to see admin menu but portal 2 has its own master and content pages.
Exception information:     Exception type: EPiServerException     Exception message: RightClickMenu requires a header control on the page. (e.g. <head runat="server" />).    at EPiServer.RightClickMenu.Render(Boolean waitForOnLoad)    at System.EventHandler.Invoke(Object sender, EventArgs e)    at System.Web.UI.Control.PreRenderRecursiveInternal()    at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Any ideas?
#73764
Aug 08, 2013 13:26
Do you have <head runat="server" /> in the masterpages for both portal1 and portal2?
#73774
Aug 08, 2013 16:42
Hi Per,
Yes I do have <head runat="server" in both master pages. I even tried ContextMenu.IsMenuEnabled = false; without success.
#73788
Aug 09, 2013 13:55
The problem seems to surface during save event after tinymce is edited or other button events.
#73789
Aug 09, 2013 14:00
The problem disappeared when I set enconding:xml in TinyMCE configuration.
#73794
Aug 09, 2013 15:28
