Search page not working properly
i'm little bit confused over my search page. When doing a product search: My Search page lists up the products correctly and it works fine untill i click on "next page" or  whatever page number. When i do that, it brings  me back to the all product  page (the first page  --> list over all products). The funny part is when i click on search button again, it shows the content of the previous page i had clicked on ( let us say page 2).
Here is my files:
Search.ascx file:
<EPiServer:PageList id="epiPageList2" runat="server">
                <HeaderTemplate>
                <table>
                    <tr>
                        <th><asp:LinkButton ID="LinkButton1" runat="server" OnClick="Search_Click" Text="Product"></asp:LinkButton></th>
                        <th><asp:LinkButton ID="Produsent" runat="server" OnClick="Producer_Click" Text="Producer"></asp:LinkButton></th>
                        <th>MainSubstanse</th>
                    </tr>
                </HeaderTemplate>
                <ItemTemplate>
                    <tr>
                        <td><EPiServer:Property ID="Property2" PropertyName="PageLink" runat="server" /></td>
                        <td><EPiServer:Property ID="Property1" PropertyName="Manufacturer" runat="server" /></td>
                        <td><%#MainSubstanse(Container.CurrentPage)%></td>
                    </tr>
                </ItemTemplate>
                <FooterTemplate>
                </table>
                </FooterTemplate>
            </EPiServer:PageList>
Code behind:
 protected void Page_Load(object sender, EventArgs e)
            PageData page = GetPage(PageReference.StartPage);
            FindPages(page, string.Empty, "PageName");
        protected void Search_Click(object sender, EventArgs e)
            FindPages(page, searchBox.Text, "PageName");
 private void FindPages(PageData page, string searchText, string SortName)
            PropertyCriteriaCollection searchCriteria = new PropertyCriteriaCollection();
            PageReference pageRef = page[PropertyContent] as PageReference;
            if (pageRef != null)
                var criterias = new PropertyCriteriaCollection
                    new PropertyCriteria()
                        Name = "PageTypeID",
                        Condition = CompareCondition.Equal,
                        Required = true,
                        Type = PropertyDataType.PageType,
                        Value = "20"
                        Name = "IsApproved",
                        Condition = CompareCondition.NotEqual,
                        Required = true,
                        Type = PropertyDataType.Boolean,
                        Value = "True"
                if (searchText != string.Empty)
                    PropertyCriteria criSearch = new PropertyCriteria()
                        Name = "PageName",
                        Condition = CompareCondition.Contained,
                        Required = true,
                        Type = PropertyDataType.String,
                        Value = searchText
                    criterias.Add(criSearch);
                var pages = DataFactory.Instance.FindPagesWithCriteria(pageRef, criterias);
                string text = "{0} product found";
                if (pages.Count > 1)
                    text = "{0} products found";
                Total.Text = string.Format(text, pages.Count.ToString());
                epiPageList2.DataSource = pages;
                epiPageList2.Paging = true;
                epiPageList2.PagesPerPagingItem = 20;
                epiPageList2.SortBy = SortName;
                epiPageList2.SortDirection = EPiServer.Filters.FilterSortDirection.Ascending;
                epiPageList2.DataBind();
 I appreciate if someone can help me.
#73835
Aug 12, 2013 15:32
Have you tried wrapping the code in Page_Load in a
if (!IsPostBack)
Any postback (i.e. search) will execute that code again without it.
#74830
Edited, Sep 09, 2013 11:49
