Are you looking for full ajax experience without a postback or is it sufficient with the fade-in effect after the postback?
Hi Alf,
Fade in effect after the postback is sufficient...
Many Thanks.
Marc.
That seems a little non-EPiServer, all you would need is to render the result with a css that hides it.
And create a javascript that is run at startup. The script fades in the results either by using JQuery animation or maybe CSS3 transitions and play with the opacity?
Depending on what browser compatibility requirements you have.
Hi Alf,
Thats fine! Was just checking for any EPiServer related anomalies.
Thanks for your reply.
Marc.
Hello,
Probably a simple one for you guys - using the basic EPiServer Search in 6 R2 - the search works how I want it to, however i want the search results to fade in (using javascript or some other method) to make the page look a bit more contemporary.
Code as follows.
<div id="mainContent" class="rounded contentArea">
<h1>How are we doing?</h1>
<div id="Searchfor">
<span class="searchtitletext"><%--You searched for:--%><asp:TextBox ID="txtSearch" runat="server" cssclass="searchinput"></asp:TextBox>
<asp:Button ID="btnSearch" runat="server" onclick="btnSearch_Click" cssclass="searchbutton" />
<br />
<br />
<EPiServer:SearchDataSource ID="sdsSearch" runat="server" PageLink="8104">
<SelectParameters>
<asp:ControlParameter ControlID="txtSearch" Name="SearchQuery" PropertyName="Text" />
</SelectParameters>
</EPiServer:SearchDataSource>
</div>
<div id="Searchresults">
<h2>Search Results</h2>
<asp:DataList ID="dlSearch" runat="server" DataSourceID="sdsSearch">
<ItemTemplate>
<li class="searchresult"><EPiServer:Property ID="propPageLink" runat="server" PropertyName="PageLink" /></li>
<p class="searchtext"><EPiServer:Property ID="propMainIntro" runat="server" PropertyName="FurtherText" /></p><p class="divider"></p>
</ItemTemplate>
</asp:DataList>
</div>
</div>
</asp:Content>
Need the Search results div to fade in once the button at the top has been pressed.
Will just use a javascript solution - but wanted to ask the experts first, to check there are no EpiServer dependant conditions I should be aware of.
Many thanks.
Marc.
