MetaObjectValidationException: Invalid validators:
I'm having an issue with business object constraints. The field in the business object is locked so I can't modify it throught the Commerce UI. This is the current issue I'm getting:
Invalid validators:
[0] The field value is too long '184'. Max length of the 'PaymentChoice' field is equal 50.
Exception Details: Mediachase.BusinessFoundation.Data.Meta.MetaObjectValidationException: Invalid validators:
Source Error:
Stack Trace:
[MetaObjectValidationException: Invalid validators:
   Mediachase.BusinessFoundation.Data.Meta.MetaObject.OnSaving() +375
   Mediachase.BusinessFoundation.Data.Meta.MetaObject.Save(Boolean forceSave) +26
   Mediachase.BusinessFoundation.Data.Business.EntityObjectDefaultRequestHandler.Update(BusinessContext context) +452
   Mediachase.BusinessFoundation.Data.Business.EntityObjectDefaultRequestHandler.Execute(BusinessContext context) +529
   Mediachase.BusinessFoundation.Data.Business.BusinessManager.Execute(Request request) +369
   Mediachase.Commerce.Manager.Apps.MetaUIEntity.Tabs.EntityEditTab.SaveChanges(IDictionary context) +1445
   Mediachase.Commerce.Manager.Core.Controls.EditViewControl.SaveChanges(IDictionary context) +280
   Mediachase.Commerce.Manager.Core.SaveControl.OnSaveChanges(Object sender, EventArgs e) +58
   System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +155
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3804
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.18044
I'm want to change that length constraint to 200 or so. The only way of doing this is via the database. Something I've tried and haven't worked either.
Thanks in advance for any advice.
#72657
Jun 25, 2013 18:14
