Episerver Scheduled Job fails (scheduler service)
Hi all,
Our scheduled jobs started failing since yesterday with the following error message:
CustomUpdate.Execute - System.NullReferenceException: Object reference not set to an instance of an object.
at System.Web.Security.Roles.GetRolesForUser(String username)
at EPiServer.Security.PrincipalInfo.CreatePrincipal(String username)
The scheduled job uses anonymous execution and logs in programmatically using the following call:
if (PrincipalInfo.CurrentPrincipal.Identity.Name == string.Empty)
     PrincipalInfo.CurrentPrincipal = PrincipalInfo.CreatePrincipal(ApplicationSettings.ScheduledJobUsername);
I have put in some more logging around PrincipalInfo.CreatePrincipal call which is in Episerver.Security and noticed that PrincipalInfo.CreatePrincipal calls System.Web.Security.Roles.GetRolesForUser(username) and Roles.GetRolesForUser(username) returns an empty string array.
There were no changes code wise or on the server (updates, etc).
I checked that the user name used to run the task is in the database and has roles associated with it.
I checked that applicationname is set up correctly and is associated with the user
If i run the job manually using the same user it executes with no issues (i know there is a difference between running the  job manually and using the scheduler)
I also tried creating a new user, that didn’t work either.
Has anyone come across the same or similar issue? Any thoughts how to resolve this issue? Thanks in advance.
#72709
Jun 26, 2013 18:16
Do you get the same behaviour if you replace ApplicationSettings.ScheduledJobUsername with the username you are logged in as (that works when you run the job manually)?
#72711
Jun 26, 2013 19:10
Yes, same behaviour. Actually its with any user.
#72714
Jun 26, 2013 20:48
Hi Per, thanks for that post. That is exactly what i did to work around the problem, however, it is not ideal and it is still not clear why the other approach is not working.
#72725
Jun 27, 2013 9:36
I have finally found a problem - application pool running with more than one worker processes (in my instance I had two worker processes). Once I set worker processes limit to one everything started to work again.
#72988
Jul 03, 2013 14:06
