Hi Jonathan,
Have you tried accessing the XForm from code and using the GetPostedData method to retrieve the encrypted data back? You could then perform decryption at this point.
Can this be used in the CMS - so for example: if you go to a page in the CMS where there is an XForm and you click on the XForm tag, the data is Encrypted, is there anyway to override the existing code to Decrypt the data?
The call needs to be when the user is viewing the data via the CMS or when exporting the data.
Cheers
I'm thinking this will be a customised page or gadget for viewing and exporting the XForms data. The in-built CMS options for presenting XForms data are not extensible from what I've been able to find.
Is it possible to EnCrypt XForm data into a database and then DeCrypt the data back out into an email and view the Form data in the CMS as either a generated Excel doc and via the CMS Composer XForm Data tab.
I can EnCrypt the data by using BeforeSubmitPostedData but then the report in the CMS Composer XForm Data tab is EnCrypted.
Many thanks for your help,
Jon
