Dynamic properties-error, 'has a SelectedValue which is invalid because it does not exist in the list of items.'
Hello,
At the website of a customer the following error occurs when clicking on Dynamic Properties of the 'Start page'. It works with other pages. What may be the cause of it and how do I solve it?
Error occured 22.04.2013 10:21:32
User IP 93.89.112.52
User Agent Mozilla/5.0 (Windows NT 6.1; WOW64; rv:20.0) Gecko/20100101 Firefox/20.0
Url http://www.oppdal.kommune.no/cmsui/CMS/Edit/EditDynProp.aspx?id=26
Referer http://www.oppdal.kommune.no/cmsui/CMS/Edit/EditCommand.aspx?
'' has a SelectedValue which is invalid because it does not exist in the list of items.
Parameter name: value
Exception Details: System.ArgumentOutOfRangeException: '' has a SelectedValue which is invalid because it does not exist in the list of items.
Source Error:
Stack Trace:
[ArgumentOutOfRangeException: '' has a SelectedValue which is invalid because it does not exist in the list of items.
Parameter name: value]
   System.Web.UI.WebControls.ListControl.PerformDataBinding(IEnumerable dataSource) +1765669
   System.Web.UI.WebControls.ListControl.OnDataBinding(EventArgs e) +109
   System.Web.UI.WebControls.ListControl.PerformSelect() +34
   System.Web.UI.WebControls.BaseDataBoundControl.DataBind() +74
   System.Web.UI.Control.DataBindChildren() +201
   System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +101
   System.Web.UI.Control.DataBind() +15
   EPiServer.UI.Edit.EditDynProp.SetupForm() +69
   EPiServer.UI.Edit.EditDynProp.OnInit(EventArgs e) +20
   System.Web.UI.Control.InitRecursive(Control namingContainer) +140
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +480
#70488
Apr 22, 2013 10:26
