In CMS6 R2 the lang files got added as embedded resorces and from your error it seems it's having trouble finding them. Could you check your episerver.config to see that your vpp paths for EPiServerShell has been updated to something along the lines of this:
"C:\Program Files (x86)\EPiServer\Framework\6.2.267.1\Application\UI"
and that the assemblybindings have been updated in the web.config for the shell dlls?
<dependentAssembly>
<assemblyIdentity name="EPiServer.Shell" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
<bindingRedirect oldVersion="1.0.0.0-6.2.267.1" newVersion="6.2.267.1" />
</dependentAssembly>
<dependentAssembly>
<assemblyIdentity name="EPiServer.Shell.UI" publicKeyToken="8fe83dea738b45b7" culture="neutral" />
Hi Petter,
I have all that code at my place, aything else I can check? :)
Hmm.. well then it's a bit more tricky I guess =)
I would try clearing your temporary ASP.Net files.
start -> cmd -> iisreset /stop
goto:
C:\Windows\Microsoft.NET\Framework64\v4.0.30319\Temporary ASP.NET Files\root
and clear it.
iisreset /start
Don't really have anything more to go on then... Well you could reflect your dll and check if the entry exists I guess
Hey, I just noticed that I got this Warning (source ASP.NET 2.0.50727.0 eventid:1309 task category: web event) in my event log:
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 2013-04-03 14:49:42
Event time (UTC): 2013-04-03 12:49:42
Event ID: 13e3aed482d0435a81c47d63be7e078f
Event sequence: 185
Event occurrence: 3
Event detail code: 0
Application information:
Application domain: /LM/W3SVC/3/ROOT-3-130094667823111729
Trust level: Full
Application Virtual Path: /
Application Path: C:\EPiServer\Sites\XXX_Intranet_CMS5_UPGRADE\Intranet_CMS6\src\
Machine name: CLT-24610XX
Process information:
Process ID: 11776
Process name: w3wp.exe
Account name: IIS APPPOOL\XXX_Intranet_CMS6
Exception information:
Exception type: ReflectionTypeLoadException
Exception message: Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
Request information:
Request URL: http://banconet.local/rb/Shell/Resources/GetLocalizationResource?typeName=EPiServer.Shell.Resources.Texts&culture=sv
Request path: /rb/Shell/Resources/GetLocalizationResource
User host address: 127.0.0.1
User: user.name
Is authenticated: True
Authentication Type: Forms
Thread account name: IIS APPPOOL\XXX_Intranet_CMS6
Thread information:
Thread ID: 15
Is impersonating: False
Stack trace: at System.Reflection.Module._GetTypesInternal(StackCrawlMark& stackMark)
at System.Reflection.Assembly.GetTypes()
at EPiServer.Data.Dynamic.TypeResolver.ResolveType(Object sender, ResolveEventArgs args)
at System.AppDomain.OnTypeResolveEvent(String typeName)
at System.RuntimeTypeHandle._GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark, Boolean loadTypeFromPartialName)
at System.RuntimeTypeHandle.GetTypeByName(String name, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark)
at System.RuntimeType.PrivateGetType(String typeName, Boolean throwOnError, Boolean ignoreCase, Boolean reflectionOnly, StackCrawlMark& stackMark)
at System.Type.GetType(String typeName)
at EPiServer.Shell.UI.Controllers.ResourcesController.GetLocalizationResource(String typeName, CultureInfo culture)
at lambda_method(ExecutionScope , ControllerBase , Object[] )
at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.<>c__DisplayClassd.<InvokeActionMethodWithFilters>b__a()
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodFilter(IActionFilter filter, ActionExecutingContext preContext, Func`1 continuation)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethodWithFilters(ControllerContext controllerContext, IList`1 filters, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName)
at System.Web.Mvc.Controller.ExecuteCore()
at EPiServer.Shell.Web.Mvc.ModuleMvcHandler.ProcessController(IController controller)
at EPiServer.Shell.Web.Mvc.ModuleMvcHandler.BeginProcessRequest(HttpContextBase httpContext, AsyncCallback callback, Object state)
Custom event details:
Just noticed that maybe I'm not alone with this(?):
http://world.episerver.com/Modules/Forum/Pages/thread.aspx?id=54656
I'm really punching in the dark here. But I see that your running your site under asp.net 2.0. So my post about emptying the temp files was incorrect. The path should be C:\Windows\Microsoft.NET\Framework64\v2.<YourVersionHere>\Temporary ASP.NET Files\root. Also if your using a 32bit system it would be just Framework and not Framework64
Thank you for helping me find a solution for this.
I dont know if you found a solution or not but here is how I solved it.
I looked in the event log and as you I had a warning. The exception however was:
Exception type: HttpException
Exception message: The 'ClientResourceCache' cache profile is not defined. Please define it in the configuration file.
So I looked in web.config for a site with a clean install of EPiServer R2 (EPiServer CMS 6.1.379.502) and found this entry:
<system.web>
<caching>
<outputCacheSettings>
<outputCacheProfiles>
<add name="ClientResourceCache" enabled="true" duration="3600" varyByParam="*" varyByContentEncoding="gzip;deflate" />
</outputCacheProfiles>
</outputCacheSettings>
</caching>
</system.web>
In the upgraded sites web.config this entry didnt exist, so I put it there and it worked.
Regards Hans Kindberg
Hi everyone!,
I have got this strange error on the Start(shell)-tab after an site upgrade from CMS5.2 to CMS6 R2.
Some links have text like "The [Edit] key does not exist in [EPiServer.Shell.Resources.Texts]." (see imagelink)
Link: http://sdrv.ms/14SgIAR
All links works but it's annoying :)
