Do you get the same error if you try and re-create the dynamic content in edit mode? (or test it on a new page).
Frederik
Thanks for you answer, yes Fredrik I've tried that, I have even created new dynamic contents and tried to use them. Same result on all dynamic content plugins in the project.
Does it preview in edit mode for you? Could you test with this code:
<EPiServer:Property runat="server" PropertyName="MainBody" />
Hello,
I'm experience the following error
Index was outside the bounds of the array.
Exception Details: System.IndexOutOfRangeException: Index was outside the bounds of the array.
Source Error:
Line 9: base.OnLoad(e); Line 10: Line 11: if (CurrentPage["MainBody"] != null) return; Line 12: Line 13: Visible = false;Source File: xxxxxxxxx\Templates\Units\MainBody.ascx.cs Line: 11
This happens when i try to access dynamic contents in my developing environment. In the mainBody I've dynamic contents, thats where the site get this error. I get this error on all dynamic contents.
Have you experienced such an error associated with dynamic content? What to check?
