Detect which window makeing request in editmode
Hello
In episerver edit mode there are a couple of frames i.e menu tree-frame, top-frame and content-frame where the actual page beeing edited is rendered.
I have to have different MasterPages based on a settings om current page being rendered and that is detected in a httmodule and masterpage is switched based on setting.... Everything works fine but not in edit mode because when masterpage is switched there will be a runtime error in edit mode.... My thought is now to just switch masterpage for page beeing rendered in content-frame so is there a way to detect which frame rendering page?
Thanks in advance!
#69121
Mar 22, 2013 10:38
Perhaps you can use this to check if you are in edit mode?
        private bool IsEditOrPreviewMode()
            HttpRequest request = HttpContext.Current.Request;
            Uri referrer = request.UrlReferrer;
            return referrer != null &&
                   referrer.Host == request.Url.Host &&
                   referrer.Segments[referrer.Segments.Length - 1]
                       .Equals("EditPanel.aspx", StringComparison.InvariantCultureIgnoreCase);
#69134
Mar 22, 2013 11:59
