Config Transform
I am trying to run a config transform on the episerver.config file, however the file starts with
<episerver xmlns="http://EPiServer.Configuration.EPiServerSection">
but a transform file must start with
<episerver xmlns:xdt="http://schemas.microsoft.com/XML-Document-Transform">
This causes the transform not to work. Is the xmlns of the original config required?
#66885
Mar 12, 2013 8:39
Nope, all you need is this :<episerver xmlns:xdt="http://schemas.microsoft.com/XML-Document-Transform">
#66886
Mar 12, 2013 9:01
There is a problem with the namespace, see http://tedgustaf.com/blog/2010/7/using-config-transforms-for-EPiServer-settings/
If i remember correctly this is a bug in the VS 2010 files, fixed in VS2010 SP1. So upgrade if you haven't already.
#66892
Mar 12, 2013 10:34
