Log in failed-problem. How do I configure so that the Windows-account of a user will be used per default
Suddenly no one could log in to the website to a EPiServer-website my company is working with.
Recently it was upgraded from EPiServer CMS 6 to CMS 6 R2, but it still was possible to login subsequently to this.
In EpiServer when searching for users: I see that each user name is mapped to a Windows-user and a SQL-user (Was this created automatically?).
The difference is that the Windows-user is prefixed with a group-name, e.g. username: komm\rohaning.
The login does not support login using the group-prefix, so when a user tries to log in it defaults to the SQL-account and the login fails (the SQL-account is apparently not mapped to the same password).
When deleting the SQL-account for a user it all works.
How do in a smooth way configure so that the Windows-account will be used per default?
Thanks!
#65808
Feb 11, 2013 12:06
Could the problem be that the Windows-passwords of the users were changed, but that the password of the SQL-users weren't updated?
#65810
Feb 11, 2013 12:23
Config-settings:
    <roleManager enabled="true" defaultProvider="MultiplexingMembershipProvider" cacheRolesInCookie="true">
      <providers>
        <clear />
        <!-- Comment the following lines when running on oracle. -->
        <add name="MultiplexingRoleProvider" type="EPiServer.Security.MultiplexingRoleProvider, EPiServer" provider1="WindowsRoleProvider" provider2="SqlServerRoleProvider" providerMap1="WindowsMembershipProvider" providerMap2="SqlServerMembershipProvider" />
        <!--  comment when running on oracle  -->
        <!-- Uncomment the following lines when running on oracle. -->
        <!--<add provider1="OracleRoleProvider" provider2="WindowsRoleProvider"
        providerMap1="OracleMembershipProvider" providerMap2="WindowsMembershipProvider"
         name="MultiplexingRoleProvider" type="EPiServer.Security.MultiplexingRoleProvider, EPiServer" />-->
        <!--Uncomment the lines above running oracle-->
        <add name="WindowsRoleProvider" applicationName="EPiServerSample" type="EPiServer.Security.WindowsRoleProvider, EPiServer" />
        <add name="SqlServerRoleProvider" connectionStringName="EPiServerDB" applicationName="EPiServerSample" type="System.Web.Security.SqlRoleProvider, System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
        <!--<add name="ActiveDirectoryRoleProvider"
            type="EPiServer.Security.ActiveDirectoryRoleProvider, EPiServer"
            connectionStringName="ActiveDirectoryProviderConnection"
            connectionUsername="DOMAIN\ADServiceAccount"
            connectionPassword="password"
            attributeMapUsername="sAMAccountName" />-->
      </providers>
    </roleManager>
    <membership defaultProvider="MultiplexingMembershipProvider" userIsOnlineTimeWindow="10">
      <providers>
        <clear />
        <add name="MultiplexingMembershipProvider" type="EPiServer.Security.MultiplexingMembershipProvider, EPiServer" provider1="WindowsMembershipProvider" provider2="SqlServerMembershipProvider" />
        <!--  comment the lines above when running on oracle  -->
        <!--<add provider1="OracleMembershipProvider" provider2="WindowsMembershipProvider"
          name="MultiplexingMembershipProvider" type="EPiServer.Security.MultiplexingMembershipProvider, EPiServer" />-->
        <add name="WindowsMembershipProvider" type="EPiServer.Security.WindowsMembershipProvider, EPiServer" deletePrefix="BUILTIN\,komm\, KOMM\" searchByEmail="true" />
        <add name="SqlServerMembershipProvider" type="System.Web.Security.SqlMembershipProvider, System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" connectionStringName="EPiServerDB" requiresQuestionAndAnswer="false" applicationName="EPiServerSample" requiresUniqueEmail="true" passwordFormat="Hashed" maxInvalidPasswordAttempts="5" minRequiredPasswordLength="7" minRequiredNonalphanumericCharacters="0" passwordAttemptWindow="10" passwordStrengthRegularExpression="" />
        <!--<add name="ActiveDirectoryMembershipProvider"
            type="System.Web.Security.ActiveDirectoryMembershipProvider, System.Web, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a"
            enableSearchMethods="true"
      </providers>
    </membership>
#65818
Feb 11, 2013 14:06
Solved when I configured it like this:
 <roleManager enabled="true" defaultProvider="WindowsRoleProvider" cacheRolesInCookie="true">
      <providers>
        <clear />
        <add name="MultiplexingRoleProvider" type="EPiServer.Security.MultiplexingRoleProvider, EPiServer" provider1="SqlServerRoleProvider" provider2="WindowsRoleProvider" providerMap1="SqlServerMembershipProvider" providerMap2="WindowsMembershipProvider" />
      </providers>
    </roleManager>
    <membership defaultProvider="WindowsMembershipProvider" userIsOnlineTimeWindow="10">
      <providers>
        <clear />
        <add name="MultiplexingMembershipProvider" type="EPiServer.Security.MultiplexingMembershipProvider, EPiServer" provider1="SqlServerMembershipProvider" provider2="WindowsMembershipProvider" />
        <add name="WindowsMembershipProvider" type="EPiServer.Security.WindowsMembershipProvider, EPiServer" deletePrefix="BUILTIN\" searchByEmail="true" />
      </providers>
    </membership>
#65843
Feb 12, 2013 10:23
