Just grant access to Report Center
Is there a way to grant access to the Report Center, but not the other Admin sections?
#76803
Nov 01, 2013 22:31
Per Nergård (MVP)
Report center is available if the user has access to edit mode. Unfortunately if the user has admin rights they can access everything and there is no built in way to set admin rights on a more detailed level.
#76804
Nov 02, 2013 9:26
Should be able to use the location element in web.config to set access rights.
Frederik
#76836
Nov 04, 2013 14:05
