property to hold internal or external url
I am using episerver cms 6 R2 edition. I'm looking for a property to hold internal (links to pages in CMS) and external url (external websites...).
I tried  "propertyUrl" like the following.
[PageTypeProperty(Type = typeof(PropertyUrl),
EditCaption = "Länk för höger topp bild",
SortOrder = 325,
Required = false)]
public virtual string PuffRightTopLink { get; set; }
When I'm access the property like this, getting error - Unable to cast object of type 'EPiServer.Core.PageReference' to type 'System.String'.
<a href="<%= CurrentPage.PuffRightTopLink %>" > </a>
Any help is appreciated. thanks.
#75597
Oct 01, 2013 8:30
If you look at the the property in admin mode, is it set to a property url? Looks like it is set to a PageReference.
PageTypeBuilder will not update the type of a property if you change it in code, that has to be done in the admin area.
#75608
Oct 01, 2013 10:29
#75610
Oct 01, 2013 10:36
