Redirect http status on address move and publish end date
Is there a way in Epi to set up addresses to redirect 301 "Move permanently" when we change the path of the page?
Also, when a type of page publish end date is do, i want to display 410 Gone, and not come to login page as default. Ideas?
#65449
Jan 30, 2013 12:39
The 301 when changing paths is not builtin EPiServer like it is in Wordpress. You may develop i yourself. Save old paths on PagePublished, PagedMoved events. Then handle all 404s and redirect them to the right page.
Try https://www.coderesort.com/p/epicode/wiki/404Handler The plugin detects all 404 and you can redirect them to the right page.
I will suggest 404 Not Found instead of 410 Gone in your case.
#65455
Jan 30, 2013 13:25
The wheel has already been invented. The Epinova.PermanentLinkKeeper plugin will handle 301s for you when you create, move or delete pages.
http://www.epinova.no/blog/arve-systad/dates/2012/5/epinova-permanentlinkkeeper-released/
#65478
Jan 30, 2013 16:15
Great, thank you! i will test it!
#65483
Jan 30, 2013 16:26
