XML Parsing Error: no element found
We are experiencing some problems after deploying changes to an EPiServer CMS 6 R2 site. The site in itself works as it should after deploy, but when we are trying to save a change in edit mode the site waits for a long time (approx 30s-60s) before it finally outputs an error message saying:
Location: {oursite's VPP path}/edit/EditPanel.aspx?id=2515
Line Number 1, Column 1:
The change we made has been saved, but we need to reload edit mode to be able to browse the site or make other changes.
If we choose to "Save and publish" the same situation and error occurs, the only difference is that this time the change we have made has been saved and published when we reload the site.
Any help would be appreciated
Best regards,
Espen Ekvang
#65256
Jan 24, 2013 7:18
It turned out to be a configuration error for ImageVault. Once the configuration was corrected it works again.
#65257
Jan 24, 2013 8:49
