Delete user popup not working after R2 update
Hello
We recently updated a site to Episerver 6 R2 and the delete user popup is no longer working.
It throws an error when being compiled according to the Episerver log:
2013-01-14 16:41:38,049 ERROR [24] EPiServer.Global.Global_Error - 1.2.5 Unhandled exception in ASP.NET
System.Web.HttpCompileException: c:\Windows\Microsoft.NET\Framework64\v2.0.50727\Temporary ASP.NET Files\root\696375e2\e9ff38fa\App_Web_deletemembershipdialog.aspx.76ff8ec2.7o8foqoa.0.cs(204): error CS1061: 'ASP.c4_cms_admin_deletemembershipdialog_aspx' does not contain a definition for 'RoleNameLabel' and no extension method 'RoleNameLabel' accepting a first argument of type 'ASP.c4_cms_admin_deletemembershipdialog_aspx' could be found (are you missing a using directive or an assembly reference?)
   at System.Web.Compilation.AssemblyBuilder.Compile()
   at System.Web.Compilation.BuildProvidersCompiler.PerformBuild()
   at System.Web.Compilation.BuildManager.CompileWebFile(VirtualPath virtualPath)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultInternal(VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
   at System.Web.Compilation.BuildManager.GetVPathBuildResultWithNoAssert(HttpContext context, VirtualPath virtualPath, Boolean noBuild, Boolean allowCrossApp, Boolean allowBuildInPrecompile)
   at System.Web.Compilation.BuildManager.GetVirtualPathObjectFactory(VirtualPath virtualPath, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
   at System.Web.Compilation.BuildManager.CreateInstanceFromVirtualPath(VirtualPath virtualPath, Type requiredBaseType, HttpContext context, Boolean allowCrossApp, Boolean noAssert)
   at System.Web.UI.PageHandlerFactory.GetHandlerHelper(HttpContext context, String requestType, VirtualPath virtualPath, String physicalPath)
   at System.Web.HttpApplication.MaterializeHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
Why is this happening?
I've tried deleting the temporary files in the path given in the exception with no luck.
Regards
/Kent
#64901
Jan 15, 2013 10:28
