Translate drop-down list property values
Is it possible to translate the name values in a drop-down list property?
#61012
Sep 04, 2012 15:35
What kind of drop down are you refering to? Something on a template? A custom property that inherits from a base class?
#61015
Sep 04, 2012 16:13
The built in drop down-list property where the values (name/value) are set through custom property settings. I want to translate the name for editors depending on their personal language when in edit mode.
#61018
Sep 04, 2012 16:19
When I look at the source code it seems that we try to find a translation for each value if it starts with a '/'-character. So basically you should give values like "/mytranslationpath/value/" and make sure that you add the correct translations to your language files and it should work.
#61019
Sep 04, 2012 16:22
