Error in Episerver CMS 5 R2 SP 2 after upgrading to 6 R2
I get Object reference not set to an instance of an object.
and following stack trace:
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
   EPiServer.Core.PropertyDataCollection.EnsureAllPageTypeProperties() +281
   EPiServer.Core.PropertyDataCollection.InitializeData() +26
   EPiServer.Core.PageData.InitializeData(IList`1 pageLanguages) +20
   EPiServer.DataAccess.PageListDB.ReadPageList(AbstractCommand cmd) +2463
   EPiServer.DataAccess.<>c__DisplayClass11.<LoadSpecificPages>b__10() +428
   EPiServer.DataAccess.<>c__DisplayClass1`1.<Execute>b__0() +58
   EPiServer.DataAccess.DatabaseFactory.Execute(Action`1 method) +55
   EPiServer.DataAccess.DataAccessBase.Execute(Action`1 action) +237
   EPiServer.DataAccess.PageListDB.LoadSpecificPages(Int32[] pageLinks) +78
   EPiServer.LocalPageProvider.GetPages(PageReferenceCollection pageReferences, ILanguageSelector selector) +170
   EPiServer.Core.PageProviderBase.GetScatteredPages(PageReferenceCollection pageRefs, ILanguageSelector selector) +441
   EPiServer.Core.PageProviderBase.GetChildren(PageReference pageLink, ILanguageSelector selector, Int32 startIndex, Int32 maxRows) +92
   EPiServer.DataFactory.GetChildren(PageReference pageLink, ILanguageSelector selector, Int32 startIndex, Int32 maxRows) +261
   EPiServer.Web.UrlSegment.GetPageBySegment(PageReference parent, String urlSegment, String languageBranch, Boolean exactLanguage) +85
   EPiServer.Web.FriendlyUrlRewriteProvider.GetPageBySegments(PageReference rootPageRef, String[] segments, String languageCode) +50
   EPiServer.Web.FriendlyUrlRewriteProvider.GetPageFromStartByPath(String path, LanguageBranch languageBranch) +138
   EPiServer.Web.FriendlyUrlRewriteProvider.ConvertToInternalInternal(UrlBuilder url, Object& internalObject) +413
   EPiServer.Web.FriendlyUrlRewriteProvider.ConvertToInternal(UrlBuilder url, Object& internalObject) +410
   EPiServer.Web.UrlRewriteModule.HttpUrlRewriteToInternal(UrlBuilder url) +313
   EPiServer.Web.UrlRewriteModuleBase.BeginRequestEventHandler(Object sender, EventArgs e) +158
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
WHAT I DID IS:
I made copy of my local dev website and upgraded it first from 5 R2 SP 2 to 6 then 6 R2 and the upgraded version worked fine.
Then I stopped upgraded website and started to work teh original old version (5 R2 SP 2) by restoring its equivalent DB to have things as they were. But now I suddenly get this strange error and I cant even hit by debug on any entry point in code.
Anyone know how to fix this ?
#61165
Sep 10, 2012 16:43
Looks like you didn't revert fully. Are you sure you're running all files (config and DLL's especially) from the 5 R2 SP2 as they were before the upgrade touched them?
#61172
Sep 10, 2012 22:35
