How do I get the Master Language?
When I use LanguageManager.Translate(string key), it will use the current culture as the language. I don't want that, so I need to use LanguageManager.Translate(string key, string language), which also takes a language parameter like "sv".
I want to use the site's master language, but I don't know where to find the language string for that. Do you?
#60647
Aug 21, 2012 9:05
You can retrieve the master language from the startpage, startPage.MasterLanguageBranch.
You can also change the CultureInfo on current thread in OnPreInit
protected override void OnPreInit(EventArgs e)
    Thread.CurrentThread.CurrentCulture = new CultureInfo("en");
    Thread.CurrentThread.CurrentUICulture = new CultureInfo("en");
    base.OnPreInit(e);
#60649
Edited, Aug 21, 2012 9:38
