Enabling web dav on both sites might be quick way to drag and drop the files between the two using windows explorer.
You could use something like this for exporting the files to Windows and then just drap/drop them onto the new installation.
Hope this helps
Frederik
Thank you for suggestions :), I'll give it a try and let you know.
Piotr
I went for Fredrik suggestion and used code block and used DumpaRump class to dump VPP files.
It worked really well
Thank you very much,
Piotr
However this doesn't provide the file summary applied to the files. How do you export with the file summary as well?
Regards,
Raja Chandran
Hello,
The problem I have to solve is:
Copy all files in VPP folders from one CMS6 site to new system based on CMS6R2. There is couple of thousnds files in there.
Anyone has done it before and could share/recomend some solutions?
Thank you a lot,
Piotr
