Dyamic content
Hi ,
I am rendering User control as Dynamic Content. With Attribute
[DynamicContentPlugIn(
        DisplayName = "Dart Flash Control",
        Description = "Dart Flash Conrol",
        ViewUrl = "~/Templates/UserControls/StaticControls/FlashScriptControl.ascx")]
When I Preview the Dynamic content its rendering with out any issue. but When I publish the page and view the page, Dynamic Content is not displayed.
Please do let me know i am missing any configration /code error.
Any help is highly appreciated.
Cheers
Hazarath
#60389
Aug 07, 2012 12:46
Are you using the EPiServer:Property control to render your XHTML property?
#60393
Aug 07, 2012 13:17
No.I m not using  Episerver.Property.
I followed the approach given here.
http://tedgustaf.com/en/blog/2011/4/creating-dynamic-content-in-episerver-cms-6-r2/
#60396
Aug 07, 2012 14:07
Yes, but I meant in the template that renders the page, I'm guessing you have a XHTML property with a name such as MainBody or something like that. In the edit mode you test inserting a dynamic content block inside the Editor for MainBody.
If you just render it like <%= CurrentPage["MainBody"] %> the dynamic content processing will not be initialized. You need to use EPiServer:Property or something like this:
http://tedgustaf.com/en/blog/2009/9/parse-an-episerver-xhtml-property-with-dynamic-content/
#60397
Edited, Aug 07, 2012 14:20
@Johan,
Thanks a lot for driving me in right direction.
Cheers
Hazarath
#60404
Aug 07, 2012 16:13
Hi Johan..
I am getting strange error: while rendering . any idea?
Control 'ctl01_ctl02' of type 'HiddenField' must be placed inside a form tag with runat=server.
Exception Details: System.Web.HttpException: Control 'ctl01_ctl02' of type 'HiddenField' must be placed inside a form tag with runat=server.
Source Error:
Line 95:
Line 96:             // Render the Property control to get the markup
Line 97:             ctrl.RenderControl(htw);
Line 98:
Line 99:
Source File: C:\Projects\OnlineRecruitment\trunk\Source\OnlineRecruitment.Web\Templates\Pages\ArticlePage.aspx.cs    Line: 97
#60411
Edited, Aug 07, 2012 17:48
You need to replace the asp:HiddenField control with something else or add a form tag with runat=server... The error message only concerns ASP.NET and your templates and has nothing to do with EPiServer.
#60417
Aug 08, 2012 9:22
