Customising EPiServer CMS User Interface
Hi Guys
I have been taksed with finding out the best ways to customise the EPiServer UI i.e. change colour scheme use own logo etc. What would be the best method for me todo this. So far my options are :
* Update the UI files within Program Files (not a chance)
* Copy the UI folders from Program Files move to a local folder within the website and update the VPP paths withing EPiServer.Config
Are their any other options i.e Theme's or being able to override the existing UI controls.
Minesh
#60448
Aug 09, 2012 15:27
I think your best bet would be to create a new theme and set it as default theme in web.config for EPiServer UI, the default theme used is called "Default": C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Application\App_Themes\Default
Frederik
#60463
Aug 10, 2012 10:54
Copy to a source code controlled local folder within the website is a good way if you need to be able to change HTML.
I don't think Themes will get you into CSS/images for the newer "Shell" views such as Online Center etc.
#60469
Aug 10, 2012 13:16
Cheers for the info, will try both methods and see what fits out needs the best
#60475
Aug 10, 2012 16:23
Using Theme's alone i do not think it is possible to modify the EPiServer Logo although colours and some other icons looks promising
#60496
Aug 13, 2012 11:33
Right i have created a new themes folder locally and updated the App_Themes_Default value in EPiServer.config file with this i can now update the logo shown on the top right, although where can i change the link, I cant seem to find where the user control is for the global header
#60559
Aug 15, 2012 17:18
as i thought the ur;s are hard coded in the assembley therefor cannot be changed
Response from EPiServer below
Unfortunately I'm afraid that you cannot change url of that logo since it was hardcoded in assembly.
You can find it is set in method GetMenuItems() class ShellMenuProvider assembly EPiServer.Shell.UI.dll by refletoring.
#60654
Aug 21, 2012 12:09
I guess you could add a HttpModule last for the UI-folder and replace the rendered markup if you really need to change the logo-URL.
#60656
Aug 21, 2012 13:01
