Shared directory path for indexing the Search results in a load balancing environment
Hello,
We are using the EPiServer.Search.IndexingService for searching text on our website. In the development environment we have created a folder for indexing the Search results. The entry in the local Web.config file is as below:-
<episerver.search.indexingservice>
                <namedIndexes defaultIndex="default">
                                <indexes>
                                                <add name="default" directoryPath="C:\Search\trunk\Index" readonly="false"/>
                                </indexes>
</namedIndexes>
</episerver.search.indexingservice>
I would like to enquire if we could use a shared directory path for indexing the Search results in a load balancing environment.
How would Episerver handle the indexing of the search generated from each server in a load balancing environment?
#60002
Jul 10, 2012 14:00
