Cannot mirror datastore data using Mirroring 2.0
I am trying to mirror some data which is held in the dynamic datastore between EPiServer sites using mirroring 2.0.
I have created a module based on TransferHandlerBase and implementing IInitializibleModule using the code from Johan Björnfot's blog post Custom Export – Handle your “own” stream as a base.
The initialize method adds an event handler to the RegisterTransferHandlers event.
            RegisterTransferHandler.RegisterTransferHandlers +=
                new EventHandler<RegisterTransferHandlerEventArgs>(RegisterTransferHandlers);
        private void RegisterTransferHandlers(object sender, RegisterTransferHandlerEventArgs args)
            if (args.TransferType == TypeOfTransfer.Exporting
                || args.TransferType == TypeOfTransfer.MirroringExporting)
                args.RegisteredHandlers.Add(new RedirectionExport());
Then the read and write methods convert the data into and out of XML.
The code works when I import or export the data. When I try mirroring, nothing happens. I have tried adding loggin and the Initialize method is called, but not the RegisterTransferHandlers.
The mirroring service is running as a seperate website with the folder within the EPiServer site folder and I have updated the mirroring services bin folder with the contents of the sites bin folder, just in case.
Any help would be really useful....
Jim
#59076
May 18, 2012 16:18
Have you deployed your code to the target site's mirroring site bin folder too?
#59299
May 30, 2012 12:00
