XForm Output - How to Style
Hello.
When the XForm sends an email out - is there any files/assembly/code that EPiServer uses that determines how this looks when it is outputted? If so, where is it!?
We wish to customise it, so wondering where to start?
Thanks.
#58470
Apr 26, 2012 10:46
First you need to create an initialization module as a container for your override code. You will find details of how to do this here:
http://world.episerver.com/Documentation/Items/Tech-Notes/EPiServer-CMS-6/EPiServer-CMS-60/Initialization/#Creating
Make sure your module is dependent on the EPiServer.Web.InitializationModule using the ModuleDependency attribute:
In the Initialize method of your module you can add the following code to customize the email output:
BaseLibrary.Channel.IChannel channel = new SynchronousChannel("xformdata");
EPiServer.XForms.Implementation.EMailConnection emailSender = new EPiServer.XForms.Implementation.EMailConnection();
emailSender.Subject = "MySubject"
emailSender.XMailer = "EPiServer XForms";
emailSender.XsltUrl = url to an Xslt file that transforms the XML Document containin the post;
emailSender.From = "";
emailSender.To = "";
channel.SendEvent += new BaseLibrary.Channel.ChannelEventHandler(emailSender.SendEmail);
channel.SendEvent += new BaseLibrary.Channel.ChannelEventHandler(new EPiServer.XForms.Implementation.HttpConnection().HttpRepost);
channel.SendEvent += new BaseLibrary.Channel.ChannelEventHandler(XForms.XFormData.SaveEventHandler);
BaseLibrary.Context.Repository.UnregisterChannel("xformdata");
BaseLibrary.Context.Repository.RegisterChannel(channel);
Please note that I have not compiled or tested this code :-)
#58531
Apr 27, 2012 15:08
