Unique Identifier using XForms
Hello All,
Is there anyway by default to have a unique ID on every row when an individual form is filled in?
Will need this for audit purposes.
Many Thanks.
Marc.
#58419
Apr 24, 2012 17:03
Not sure what you mean. But every form posting is a row in the database and every row has an identifier of some kind.
#58422
Apr 24, 2012 18:43
Hi Johan,
Basically in the database table within EPiServer, which displays all the results, we need the auto generated field to appear in the results, infront of the other fields.
#58436
Apr 25, 2012 13:39
Do you mean in the "Form Data" tab in edit mode?
#58438
Apr 25, 2012 14:00
Hi Johan,
Yep, thats the one. So when its exported into excel, there will always be the unique ID displaying next to each row.
#58439
Apr 25, 2012 14:08
Maybe there is an event you can listen to and add an id to each row in the exported file.
But I would listen to an event when the form is posted and then add a guid to the posting. You can add columns on the fly to a posting, it doesn't need to be in the xform definition.
#58453
Apr 25, 2012 14:24
Roughly (not compiled) :
protected void Application_Start(Object sender, EventArgs e)
XFormControl.ControlSetup += new EventHandler(XForm_ControlSetup);
public void XForm_ControlSetup(object sender, EventArgs e)
XFormControl control = (XFormControl)sender;
control.BeforeSubmitPostedData += new SaveFormDataEventHandler(XForm_BeforeSubmitPostedData);
public void XForm_BeforeSubmitPostedData(object sender, SaveFormDataEventArgs e)
e.FormData.SetValue("MyKey", new Guid().ToString());
#58456
Apr 25, 2012 15:55
