Hi Marc,
You sould be able to set up a diffrent account running the service on the other site. The important thing is that the user your using has permitions to run it.
Some questions:
What authentication are you using on the main site?
What authentication are you using on the first reciving site?
What authentication are you using on the second reciving site?
Hello!
I am required to mirror some content from one main site, into two separate places.
Am looking in the web.config for the source site, in which there is the node...
<add defaultEndpointName="mirroringTargetEndPoint" chunkSize="4194304" name="MirroringTransferServer" type="EPiServer.MirroringService.MirroringTransferProtocol.WCF.MirroringTransferClient,EPiServer.Enterprise" username="itc-jp" password="obviouslythereisapasswordherebutdontwanttoputit" domain="glos.nhs.uk" />
This works fine mirroring into the one site.
However, the other site has never heard of a user called itc-jp *is an AD account* so is there anyway of adding another authenticated user in this config?
Cheers.
Marc.
