Problem with viewing the EpiServer CMS
Sometimes when i'm using the CMS of EpiServer i getting a strange layout (screenshot below) of the CMS. I can solve this by recycling the application pool in IIS or change the web.config and save it.
Does somebody has a solution for this problem?
#57795
Mar 28, 2012 10:39
Hi Patrick,
I've seen this before with Commerce. What you can try to do is rename the app_themes folder in your web root.
In that folder you will find an icon for Commerce. Copy this icon to the CMS folder in program files (ex C:\Program Files (x86)\EPiServer\CMS\5.2.375.236\Application\App_Themes). It should lie in the same folder structure inside the App_Themes folder. Can't say what the folders are right now as I don't have a Commerce installation in front of me.
Then restart IIS and the problem should not appear again.
#57798
Mar 28, 2012 11:13
Thanks Toni. I will try that.
#57800
Mar 28, 2012 11:38
HI,
Add the below entries in web.config entries
<location path="App_Themes/Default">
    <system.web>
      <httpRuntime maxRequestLength="1000000"/>
      <authorization>
        <allow roles="WebServices,Administrators"/>
        <deny users="*"/>
      </authorization>
    </system.web>
 </location>
Regards
Venkata Phani
#57954
Apr 05, 2012 8:13
