Problem installing latest CMS 6 R2
Release Date: March 12, 2012, File Version: 6.1.379.501, Assembly Version: 6.1.379.0
Tried installing a clean CMS 6 R2 and got this far:
Error - Failed to Deserialize object to Dynamic Data Store. Method not found: 'Boolean EPiServer.Personalization.VisitorGroups.VisitorGroupValidation.Validate(System.String ByRef)'. (first error, 46 errors in total)
...Copied Global.asax.cs
Data Import error: Failed to Deserialize object to Dynamic Data Store. Method not found: 'Boolean EPiServer.Personalization.VisitorGroups.VisitorGroupValidation.Validate(System.String ByRef)'.
An error has occured and the transaction will be rolled back
Error dropping database user 'xxxxx'. Please drop manually.
A transport-level error has occurred when sending the request to the server. (provider: Shared Memory Provider, error: 0 - No process is on the other end of the pipe.)
Failed to rollback creation of directory C:\EPiServer\Sites\MyEPiServerSite
The process cannot access the file 'C:\EPiServer\Sites\MyEPiServerSite' because it is being used by another process.
Rolledback
An unhandled error has occured:
When executing
At C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\AlloyTech\Ins
tall AlloyTech.ps1:100 char:20
+ Add-EPiServerData <<<< $importSource $selectedWebApplication.PhysicalPath
$selectedWebApplication.ApplicationName -updateStartPageAttribute
True
Get-EPiIsBulkInstalling
When executing
At C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\AlloyTech\Install AlloyTech.ps1:100 char:20
+ Add-EPiServerData <<<< $importSource $selectedWebApplication.PhysicalPath $selectedWebApplication.ApplicationName -updateStartPageAttribute
System.Configuration.Install.InstallException: Failed to Deserialize object to Dynamic Data Store. Method not found: 'Boolean EPiServer.Personalization.VisitorGroups.VisitorGroupValidation.Validate(System.String ByRef)'. (first error, 46 errors in total)
at EPiServer.Install.CMS.Modules.Installers.DataImporterWrapper.VerifyNoErrors(ImportLog importStatus)
at EPiServer.Install.CMS.Modules.Installers.DataImporterWrapper.Install()
at EPiServer.Install.Common.AppDomains.RunInAppDomainInstaller.Install(IDictionary stateSaver)
at EPiServer.Install.InstallationManager.Install(Installer installer)
at EPiServer.Install.CMS.Modules.ModulesInstallationManager.ImportData(InstallationManager installationManager, String destinationDirectory, String virtualDirectory, String importSource, DatabaseDestination destination, Boolean updateStartPageAttribute, TimeSpan transactionTimeout)
at EPiServer.Install.CMS.Modules.CmdLets.AddEPiServerData.ProcessRecord()
at System.Management.Automation.Cmdlet.DoProcessRecord()
at System.Management.Automation.CommandProcessor.ProcessRecord()
Anybody experienced this too?
#57480
Mar 15, 2012 16:36
This error occurs only when installing a new site with the AlloyTech templates. Doesnt matter if you choose Include Workroom content. Installing the basic site without any content worked fine.
#57484
Mar 15, 2012 17:23
Only installing the workroom content and not the AlloyTech templates gives the same error.
#57485
Mar 15, 2012 17:25
Mar 15, 2012 17:25
Ok, I'm back to this error again. I didn't need to solve it earlier but now I kinda need to install some sample content. Nobody else got this error since the new EPiServer was relased? I find that hard to believe.
#57753
Mar 26, 2012 14:52
ok, a quick and dirty solution:
copy the files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\AlloyTech
and the import files from C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\AlloyTech\util\setup
Simple as that - shame the deployment center is broken tho :(
#57756
Edited, Mar 26, 2012 14:57
Except it wasn't so simple right?
When importing the content then I got these errors... which i recognised somewhere strangely enough:
The following errors have occurred:
Number of pages: 172
Number of page types: 32
Number of categories: 5
Number of frames: 2
Number of dynamic property definitions: 10
Number of tabs: 10
Number of files: 26
Number of imported visitor groups: 5
#57757
Mar 26, 2012 15:17
Can't really help you John, never seen this before. I suggest you get in contact with the support or do a "do over". Start from scratch.
Uninstall everything, re-download the latest release together with the latest templates and start fresh.
#57758
Mar 26, 2012 16:38
It seems the content was imported. I see pages in Edit-mode. I have started a ticket with support
#57760
Mar 26, 2012 16:45
I also get this error when trying to add the sample package for EPiServer Commerce.
String ByRef)'. (first error, 50 errors in total)
When executing
At C:\Program Files (x86)\EPiServer\CMS\6.1.379.0\Install\Modules\EPiServer Eno
teca 1.1.2.62\Application\Install_Enoteca.ps1:316 char:18
+ Add-EPiServerData <<<< $episerverDataFile $selectedWebApplication.PhysicalPa
#58335
Apr 19, 2012 16:48
Stefan: Are you also using the latest general hotfix for R2?
#58336
Apr 19, 2012 16:51
Indeed I am!
#58337
Apr 19, 2012 16:52
... and I also get the error when trying to install Alloy Tech sample package. Seems to be " $episerverDataFile $selectedWebApplication.PhysicalPath $selectedWebApplication.ApplicationName -updateStartPageAttribute" that cauese the error there too.
#58338
Apr 19, 2012 16:53
I have an open ticket but its a low priority issue for me now. EPiServer want to run a webex session and see it for themselves. They don't get the error on a clean install of EPiServer 6 R2 - must be my server that is dirty.
#58339
Apr 19, 2012 17:17
Any workarounds would be much appreciated as this is currently blocking me from doing an evaluation of EPi Commerce.
#58340
Apr 19, 2012 17:18
@John, are you by change involved in the Falcon CTP program (and have installed any of the CTPs)?
#58341
Apr 19, 2012 17:19
After uninstalling everything EPiServer related (CMS6, CMS6 R2, CMS6R2-hotfixes and 5 falcon CTPS) and installing CMS6R2-hotfixes again things are working again. So something was interfering althought I can not say exactly what caused the error.
#58377
Apr 23, 2012 8:04
Was it really necessary to install the hotfixes again? The latest R2 installation has the hotfixes included. Unless there are new hotfixes I dont know about since march?
#58381
Apr 23, 2012 8:42
With "CMS6R2-hotfixes" I mean the (current) version of R2 that has the hotfixes included so no, it's not needed to install the hotfixes seperatly. Sorry for the confusion.
#58382
Apr 23, 2012 8:45
Ok, great - good for you :)
My guess would be some kind of mismatch with the DLL's and the GAC. On a totally clean machine I guess it wouldnt be a problem.
#58383
Apr 23, 2012 8:49
I get this error when trying to export a page type and also select "Export property settings".
A clean reinstallation is not an option.
I want to export the custom settings for the two drop down list properties I have on my page type.
I guess I should report a ticket to the support.
#59493
Edited, Jun 13, 2012 10:31
@Andreas, I got same problem as yours when import "Visistor Groups".
Do you a solution for this without reinstallation everthing?
#61744
Oct 01, 2012 10:01
No, sorry. I did not export the settings, had to redo them manually.
#61745
Oct 01, 2012 10:04
