Default Export Behavior
When exporting a page that has PageShortcutType set to FetchData, from one solution to another solution, shouldn't the Page ShortcutType be reset to 'Normal'?
Just tested this in an Alloy Sample Site - if the page your fetching data from doesn't exist in the new site, the "Internal Shortcut/Fetch Data from" value is empty, while the LinkType remains 'FetchData',
#57304
Mar 09, 2012 14:59
