Hi Chris,
this is not an error, it is actually how it is supposed to work - while elements get replaced, the classes get applied. You can use the "remove formatting" button to easily remove existing styles.
I just wanted to add that you can remove formatting by clicking the "Styles" (marked in grey) word in the styles drop down. Just a tip if you don't want to add the "remove formatting" button.
I've added some custom class styles into a css file for the editor to use, these new styles are picked up correctly when I edit some content so this portion is working.
There seems to be a wierd issue though, where instead of changing the class name of an element it keeps adding the new style to the end of the element.
My styles in dropdown: Red, Amber, Green
My Custom CSS:
h4.green {ChangeElementType: true; EditMenuTitle: Service Status Styles; EditMenuName: Green ; background: url(../img/green-dot.png) left center no-repeat; }
h4.amber {ChangeElementType: true; EditMenuName: Amber ; background: url(../img/amber-dot.png) left center no-repeat; }
h4.red {ChangeElementType: true; EditMenuName: Red ; background: url(../img/red-dot.png) left center no-repeat; }
In the editor after changing the CSS style from the drop down: <h4 class="amber red green">Test Header</h4>
Have i missed something really obvious here?
