Not a property settings expert, but I guess the reason existingDef == null is because the DDS doesn't have a Store named typeof(ProductPickerProperty).FullName. If it is null, then you probably need to create it first with StoreDefinition.Create(....).
ok, i have my days full with other stuff, i will try this.
So you have to Create new stores for new stuff always? didnt know, do you have a good article of this DDS?
What about the TinyMCE setting, any idea? ValidateAgainstMappings seems good there.
HI all experts!
I do get "Object reference not set to an instance of an object"-error message when saving PropertySettings in EditPageTypeGlobalSettings.aspx
I have read this thread on same issue:
http://world.episerver.com/Modules/Forum/Pages/thread.aspx?id=39719&pageIndex=1
But the "existingDef" is null in my initialization module.
What should i do? I don't understand what typeof i should put? can someone explaine why and how, thank you. =)
What i have done is to add a new EPiServer.Business.Commerce.Plugins.ProductPicker.SpecializedProperties.ProductPickerProperty, and i want to put a default template (ascx) to the property.
the url to Add Settings is (/CMS/Admin/EditPageTypeGlobalSettings.aspx?value=EPiServer.Business.Commerce.Plugins.ProductPicker.SpecializedProperties.ProductPickerPropertyControl,%20XXX.Externweb.Web,%20Version=0.6.0.0,%20Culture=neutral,%20PublicKeyToken=null)
I also have the same save problem in Edit global settings for TinyMCE (EPiServer.SpecializedProperties.PropertyXhtmlString), Should i use EPiServer.Editor.TinyMCE.ToolbarRow? or EPiServer.Editor.TinyMCE.TinyMCESettings? Please explaine better? if a do so, none is passing throu to "if (!existingDef.ValidateAgainstMappings(...."
And why should i do the things Johan Kronberg maid, what does it do?
