Logged in user cannot access EPiServer Edit/Admin
I have some problems with a solution where I try to log in to EPiServer Edit-mode (or admin).
I provide username and password, but redirect doesn't kick in.
The authentication happens (I get the session-cookie and there is no "Loggin failed"-text), but no redirect.
Any good ideas of what could cause this?
#56964
Feb 17, 2012 17:33
Hi Anders!
You are probably logging in with a user that doesn’t have access to edit/admin. The authentication is valid and you will be logged in, but when trying to browse the edit-/admin mode you will be redirected to the login page again. Check that the user is member of the groups required to access edit/admin.
/Klas
#56965
Feb 17, 2012 18:17
Well, this is embarrassing...
You were correct. I had another problem when I created the user (admin mode looked like trash, without any style) and I had to create the user by filling out things in the mark-up with Firebug. Obviously the groups didn't get right when I created the user by coping the html.
My face is now red as a tomato :)
#56966
Feb 17, 2012 18:45
No worries, good to hear that you solved the problem!
#56979
Feb 20, 2012 11:40
