Access to the path sitemap.xml is denied.
Saving a new page i get this error:
Access to the path 'C:\EPiServer\Sites\SiteName\sitemap.xml' is denied.
Exception Details: System.UnauthorizedAccessException: Access to the path 'C:\EPiServer\Sites\SiteName\sitemap.xml' is denied.
ASP.NET is not authorized to access the requested resource. Consider granting access rights to the resource to the ASP.NET request identity. ASP.NET has a base process identity (typically {MACHINE}\ASPNET on IIS 5 or Network Service on IIS 6 and IIS 7, and the configured application pool identity on IIS 7.5) that is used if the application is not impersonating. If the application is impersonating via <identity impersonate="true"/>, the identity will be the anonymous user (typically IUSR_MACHINENAME) or the authenticated request user.
To grant ASP.NET access to a file, right-click the file in Explorer, choose "Properties" and select the Security tab. Click "Add" to add the appropriate user or group. Highlight the ASP.NET account, and check the boxes for the desired access.
Source Error:
Stack Trace:
[UnauthorizedAccessException: Access to the path 'C:\EPiServer\Sites\SiteName\sitemap.xml' is denied.]
   System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) +12898791
   System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath) +2481
   System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy) +229
   System.IO.FileStream..ctor(String path, FileMode mode) +106
   SiteName.Web.Classes.SitemapHelper.WriteSitemapFile(PageReference pageReference) in C:\Utveckling\SiteName\Classes\SitemapHelper.cs:29
   SiteName.Web.Global.OnPageStructureChanged(Object sender, PageEventArgs e) in C:\Utveckling\SiteName\Global.asax.cs:119
   EPiServer.PageEventHandler.Invoke(Object sender, PageEventArgs e) +0
   EPiServer.Core.PageStoreBase.RaisePageEvent(Object key, PageEventArgs eventArgs) +127
   EPiServer.DataFactory.Save(PageData page, SaveAction action, AccessLevel access) +887
   EPiServer.Web.PageExtensions.SaveCurrentPage.SavePage() +147
   EPiServer.PageBase.SavePage() +641
   EPiServer.UI.Edit.EditPanel.SavePage() +305
   EPiServer.UI.Edit.EditPageButtonControl.Publish_Click(Object sender, EventArgs e) +24
   EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +254
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3707
#64265
Dec 14, 2012 16:06
In your code: C:\Utveckling\SiteName\Classes\SitemapHelper.cs you seem to be writing to sitemap.xml.
To solve it I guess you need to give your applicationpool identiity access to write to C:\EPiServer\Sites\SiteName\sitemap.xml
#64276
Edited, Dec 14, 2012 17:00
