From the TinyMCE editor object, how do I load a named settings configuration?
How do I load TinyMCE using custom settings?  I have created a custom configuration called "Comment Editor."  I want to load this in my template.  I have this code, which works:
var editor = new Editor.TinyMCE.Editor();
            editor.PropertySettings = (TinyMCESettings) CurrentPage.Property[0].GetSetting(typeof (TinyMCESettings));
But this loads the default settings, not my custom, named settings.  I can't figure out how to get at my named settings.
#63409
Nov 19, 2012 15:17
Have you tried GetGlobals() to find the correct one?
var p = new PropertySettingsRepository();
var globals = p.GetGlobals(typeof( ...
#63414
Edited, Nov 19, 2012 17:21
I'm still fuzzy on how that gets me a named property setting...
#63418
Nov 19, 2012 17:28
foreach (var setting in globals)
        if (setting.DisplayName.Equals("Comment Editor", StringComparison.OrdinalIgnoreCase))
#63419
Nov 19, 2012 17:30
I actually found another way around it.  I create an new empty page of the Comment type, then pull the settings off the property I wanted.
That probably makes sense, since those settings are bound to that property.  I do have a PageData object that I just throw away without saving, but I can't see how that's a problem.
editor.PropertySettings = (TinyMCESettings)comment.Property["MainBody"].GetSetting(typeof (TinyMCESettings);
#63429
Nov 19, 2012 19:02
Is there a way you could do the same with PageTypeBuilder? I mean just select the default settings for TinyMCE without creating the settings in code?
#66102
Edited, Feb 20, 2013 10:58
So, on startup you want anything that's not the Default setting to be set back to the Default setting?
Or do you want all Setttings gone and revert to the out-of-the-box EPiServer config?
The out-of-the-box toolbars are not optimal IMHO so I need an "own" setting anyway... Blogged about it a while back:
http://krompaco.nu/2012/09/page-type-builder-and-tinymce-global-settings/
#66104
Edited, Feb 20, 2013 11:25
